Hello,
Problem :
I have idle issue for several months now with my MINI Cooper S F56 2.0 192 with automatic transmission.
When I put it in P ou N (sometimes in D but never in R), the idle gradually rises to 1500rpm then goes down to 500rpm and so on.
This only happens when the engine is warm. I don't have any check engine light. No weird behavior when the car is rolling.
I went to MINI who has never seen this problem before.
Hypothesis :
My thought is the pre-cat O2 sensor (upstream) is faulty causing the ECU to poorly regulates fuel.
I tried to check sensor values through OBD port but don't have enough knowledge about those sensors.
Spark plugs are new, I run only RON 98.
What do you think about it ?
Problem :
Hypothesis :
