1 - 10 of 10 Posts
I recently retrofitted OEM Union Jack lights (look great, v grateful for advice from the forum), but I‘m looking to have a few separate issues looked at by Mini, hopefully under MOT protect.
Will they care about the retrofitted lights?
If so, would you bother swapping the stock lights back on?
Cooper S Works 210
They shouldn't be interested in the lights if they're genuine ones.
What issues are you having?
Discussion Starter #3
It’s a Cooper D and has a check engine light, OBD scan and some googling implies carbon clogged pressure sensor pipe.
Also yesterday, an error flagged up about vertical headlight beam alignment issue, and from googling has scared me about the integrity of the wiring loom.
Head beam alignment and check engine light would cause the car to fail an MOT, so my understanding is that Mini would act on this under MOT protect?
Cooper S Works 210
As you have MOT protect i'd assume you have warranty? if so that should cover the problems
How old is the car as some early 14-16 had electrical faults caused by water running from the scuttle panel into the wiring in the footwells
Discussion Starter #5
It’s a 2015 Cooper D, I believe the TLC pack with it covers its first 3 MOTs under MOT protect?
Cooper S Works 210
Ah not sure on the TLC - i know there used to be different options
Does MINI tlc pack include mot?
The benefits of this include: 12 month MINI Warranty. 12 month MINI Roadside Assistance. 12 month MOT and MOT Cover.
MINI MOT Protect Terms and Conditions 1. MOT Protect cover as part of the MINI tlc package, will rectify any technical issues described hereafter that cause the vehicle to fails its second and third MOT, which will be due no later than 48 and 60 months from the date of first registration. MOT Protect cover for the first MOT is covered as part of the Dealer Warranty. MOT Protect is included within the Dealer Warranty for the first MOT at 48 months in Northern Ireland. 2. All items will be covered with the exception of windscreens, wheels, tyres and items replaced as part of routine servicing (eg. Brake discs and pads), modified and/or non MINI components. The cost of the MOT test, re-test and advisories will not be covered, neither will failure as a result of neglect or adjustments and damage resulting from impact or accident, or faulty repair of any item covered. Vehicles used for competitions, racing, pace making, or rallies are excluded. 3.The MOT repair work has to be carried out by a MINI Authorised Works op within 30 days of the MOT inspection failure. 4. The vehicle must have a complete service history according to manufacturer’s criteria. 5. MINI MOT Protect cover is only included in MINI tlc policies purchased from 1 January 2014.
They won't care about the tail lights being swapped. You may find the pressure sensor just needs a clean. Quite a few videos on YouTube showing you how to do it. Do you have the halogen or LED headlights?
Discussion Starter #8
Gave the cleaning of it a go, was completely filthy, went off for a while, came back ~100 miles later. A few threads on the forum talk about the pipe to the sensor being clogged with carbon, which I’m hoping is the only issue.
Just thought that if I can now have that looked at along with the vertical alignment at no cost, would be ideal.
Headlights are halogen.
Discussion Starter #10
Here are the codes that flag up, haven’t seen the Climate or Entry&Start codes before scanning just now...
8011F9
ECU: Climate
Pending, Confirmed, Test failed since last DTC clear
8041E2
ECU: Entry&Start
Pending, Confirmed
8041B6
ECU: Entry&Start
Pending, Confirmed
290900
ECU: Engine Control Unit
Pending, Confirmed
2AB600
Archive (Inactive)
28EC00
279000
28DE00
Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
P00BD
Confirmed
Mass air flow (MAF) sensor A - circuit range/performance
P0471
Confirmed
Exhaust gas pressure sensor - range/performance problem
1 - 10 of 10 Posts
