Right, I promised a guide. With NewTIS getting pulled, I cannot get the full-size images anymore, but luckily I had already made my own MS Word document as I find it easier to work from paper than screens when following instructions.
NOTE: These instructions are specific to the F54 Clubman I cannot take any responsibility if they do not work for other models.
ALSO: I believe only the F54 Clubman and F60 Countryman can be fitted with a towbar.
/!\ /!\ /!\ DISCLAIMER /!\ /!\ /!\
FOLLOW THESE INSTRUCTIONS AT YOUR OWN RISK - I AM NOT A PROFESSIONAL. IF YOU ARE UNSURE, GET PROFESSIONAL HELP. I CANNOT AND WILL NOT BE HELD ACCOUNTABLE FOR DAMAGE TO YOU, YOUR VEHICLE, OR OTHERS AND/OR THEIR VEHICLES. EITHER DIRECTLY DURING THE INSTALLATION PROCESS OR DUE TO FAILURE OF A PART AFTER THE INSTALLATION PROCESS
Rather than copy out all the documentation, I will instead attach the PDFs.
Special mention goes out to
Bill Taylor, who posted the following in
Retrofitting OEM backup camera coding issues
Hopefully we can offer some help, at the very least minimise surprises!
I have attached the BMW fitting instructions which claimed to be for F45/F46 (translated from the original German version I found online). Whilst obviously the details will be different for F48/F55/F56, electrically they are identical. ...[SNIP]
It is his PDF I have attached for the Rear Camera.
I will also list the part numbers I used, and where I have them, I will list the parts that have been superseded or the parts that supersede the part number I used.
I bought some parts direct from BMW, and some from eBay, I will also list what I paid. It is possible you can get more of the parts from eBay than I did, and therefore have a cheaper install. All prices are in Great British Pounds Sterling (GBP) and include VAT if charged.
Prices are subject to change and are beyond my control, they are given purely for evaluation purposes only.
Once install I added the codes for each to the FA(VO), injected the CAFD, and then coded.
To obtain Esys, have a look here:
Bimmerfest.com > BMW Coding and Programming
With regards to the coding instructions attached, where it says click on "Read SVT", click on "Read ECU" instead.
I am still getting a camera failure error, but everything is working fine. I believe this is down to the hole I butchered in the rear bumper and, as a result, the camera is slightly twisted.
Right - parts... I ordered some parts direct through my local BMW dealership. I would have ordered through
shop.mini.co.uk - Retrofitting & Conversion accessories, but some parts were either superseded or out of stock, and it wouldn't let me.
031095 RETROFIT KIT,TRAILER TOW HITCH,REMOVABLE
Parts you
WILL need:
71 60 6 875 020 - Scdel. of tow.hitch+detach.ball head
£467.00 direct from BMW
51 48 7 375 658 - Heat insulation, bumper, rear
£27.90 direct from BMW
Supersedes:
51 48 2 585 391
71 60 2 245 628 - Retrofit kit, electr. additional parts
£212.00 direct from BMW
63 11 9 463 373 - Control unit for trailer hitch*
£130.00 direct from BMW - *NOT the part number listed on shop.mini.co.uk!
Supersedes:
71 60 6 889 590,
71 60 6 884 356,
71 60 6 879 427,
71 60 6 874 849,
71 60 6 872 320,
71 60 6 870 518,
71 60 6 867 932
Parts you
MIGHT need:
61 13 6 814 611 - Bus interface 10x
£15.90 direct from BMW -
ONLY required if CAN-BUS resistor R2 not present
Supersedes:
61 13 9 266 838
71 60 6 872 066 - Holder
£8.90 direct from BMW - Claims not included with the kit, but
WAS included in my kit.
61 14 9 270 357 - Fuse carrier
£15.96 direct from BMW - Not mentioned on shop.mini.co.uk, only mentioned in instructions
Hexagon nut with washer - The size of this is not specified, which is strange, but I didn't have a mounting bolt for it to go on anyway. Instead, I used an expanding hollow wall fixing to mount the holder using an existing hole in the inner bodywork.
Additionally, you may need 20 Amp standard blade fuses x3 and 5 Amp mini blade fuses x6. Instructions say not supplied yet, IIRC, they were supplied (although I have plenty spare anyway).
Total cost to me: £877.66 - and YES, aftermarket ones are cheaper, don't need coding, and might even have all 13 pins connected instead of the 9 in the Genuine BMW Mini towbar! As a factory option, this was £655 if fitted when ordering new. They also wanted £500 odd in labour to fit! Claiming the labour was a half-price offer. Considering I have heard of people being priced in excess of £2,000 for BMW to retrofit this, that half-price offer seems credible!
032049 RETROFIT KIT PDC, REAR
Parts you
WILL need:
66 20 2 408 603 - Retrofit kit PDC, rear
£105.00 direct from BMW
66 20 9 375 565 - Insert
£7.75 direct from BMW
51 12 7 407 933 - Grill, bumper, rear left
£27.48 direct from BMW -
NOTE this part is for an aero kit, if you have a standard rear bumper, you will need a different part
51 12 7 407 934 - Grill, bumper, rear right
51 77 7 381 965 - Support, PDC-sensor interior left
£13.78 direct from BMW
51 77 7 381 966 - Support, PDC-sensor interior right
66 20 9 274 428 (x2) - Ultrasonic sensor, black 5.7.1 AXIAL
£15.41 each (£30.82) from eBay for pattern parts. New genuine BMW are ~£116 each !!!
66 20 2 409 651 (x2) - Ultrasonic sensor, color code - NOTE: This is a control number for Individual and unlisted colors. Follow th link and select the part number from the list for your colour.
£25.00 and £18.60 genuine used parts from eBay. New genuine BMW colour coded are ~£178 each !!!
66 33 7 938 196 - Control unit PDC
£46.90 genuine used part from eBay. New genuine BMW are about £230 !!!
Supersedes:
66 33 9 865 400,
66 33 6 836 883,
66 33 6 828 085,
66 20 6 819 195,
66 20 6 805 061,
66 20 9 117 847,
66 20 9 382 516,
66 20 9 363 680,
66 20 9 350 707,
66 20 9 337 659,
66 20 9 327 352
Parts you
MIGHT need:
Supersedes:
61 13 9 266 838
Total cost: £316.59 to me: As a factory option, this was £320 if fitted when ordering new.
REAR VIEW CAMERA - there is no genuine retrofit kit for this for Mini.
Parts you
WILL need
61 11 9 390 807 - Rep.cable rearview camera
£91.99 from eBay - around £87 from BMW direct
66 53 9 475 687 - Reversing camera
~£370 direct from BMW
Supersedes:
66 53 9 475 688,
66 53 9 472 922,
66 53 9 472 923,
66 53 9 109 856,
66 53 7 951 084,
66 53 6 997 903,
66 53 9 869 525,
66 53 6 821 230,
66 53 9 396 832,
66 53 9 390 542, (
66 53 9 365 048),
66 53 9 353 705,
66 53 9 324 247,
66 53 9 339 199
66 53 9 365 048 is listed separately with no supersedes or superseded.
51 12 7 370 614 - Mount for backup camera
~£18.50 from BMW direct
51 24 7 345 709 - Cover for rearview camera
~£17.25 from BMW direct
I got lucky and got the camera, cover, and mount combined from eBay for £53.48.
Parts you
MIGHT need:
ONLY required if CAN-BUS resistor R3 not present
Supersedes:
61 13 9 266 838
Total cost to me: £153.47. As a factory option, this was £310 if fitted when ordering new.
IMPORTANT NOTE: If you do not have R3 present and are only fitting the reversing camera, you may have to make your own wiring harness to mount R3 as it doesn't seem to exist as a part. I do not have the part numbers for the plug, I could probably find them if I looked hard enough, but I have finished my holiday and am back to work so I don't really have the time. Sorry.
Instructions are attached
EBA 2245618 / 01 29 2 245 618 / 01292245618 - Dated 06/2016 - Towbar F54
EBA 2245620 / 01 29 2 245 620 / 01292245620 - Dated 12/2017 - Rear PDC F54
EBA 2447604 / 01 29 2 447 604 / 01292447604 - Dated 05/2016 - Reversing Camera F45 F46
