21 - 32 of 32 Posts
Sorry for uploading this old post, but I'm installing the rear-view mirror, I already have everything installed and I need to get the cable that connects to the distributor box pin no. 15 z7, but I can't get the original reference to ask bmw, does anyone know?
I also have a problem when mounting the ceiling panel, the upholstery comes off every time I fit the ceiling panel, does anyone know a solution or has it happened? Thank you.
Discussion Starter · #23 ·
As an ex BMW parts manager, the easiest way you are going to get the part number is to ask you local dealer to contact the factory and ask them.
It would be a lot easier to use the alternative +12v power source that I noted at the end of the write up.
I'm going to be doing this retrofit myself onto my F54, and I am helping someone else with their F56.
Can I confirm that we are running Pin 6 from A60*1B and splicing it into the already populated pin 2 on E131*2B?
From what I am seeing on NewTIS, Pin 41 on A258*4B is K_LIN_15, which splits at X226*1V and runs to the interior light (pin 2 E131*2B), the rain/light sensor (pin 2 B156*1B), and the elctrochrome mirror (pin 6 (2 in Japan) A60*1B).
In which case, would it not be easier to use a t-tap or scotch lock in place of solder?
Discussion Starter · #26 ·
Yes, as long as you are getting a good connection, scotch locks will work. My personal preference is to solder.
Thanks to this article I have successfully installed an auto dimming interior mirror - YAY.
The crimp tool I got from amaxon was useless, it didn't crimp tight enough.
So I tried to obtain part number 0006663 (61 13 0 006 663) - Contact bushing MQS with cable.
This part is now superceded. On eBay, the cheapest I can get it is £6.31 each.
I got the superceded part direct from BMW at £2.54 each. This part has a teal coloured cable, and is terminated at both ends. I bought 5.
The new part number is 0056960 (61 13 0 056 960)
If you decide to buy from eBay, you can search on both the above numbers, and also 0030852 (61 13 0 030 852), which was superceded by 0006663.
Green Technology Cable Electronic device Electronics Vehicle Car Vehicle door Windshield Driving
I cut it in half and it was just long enough.
I used a pair of 5 Amp scotch lock style connectors from Halfords to tap into the wiring in the roof function centre.
Electrical wiring Wire Cable management Cable Technology
I then coded with Esys.
I have added both 430 and 431 to the FA as I also added an exterior dimming mirror at the same time.
Rather than manually code the lines, I simply told Esys to code the BDC ECU. It's the only one that needed doing.
Presto, all working as it should.
For more info on the exterior mirror side, see this thread: Ordered foldable chromatic mirrors. Is it Plug and play?
Thanks for the info! I did the retrofit and it works great! I bought a mirror for €65 on eBay and ordered the plug from BMW.
My car has the rain sensor option, but I don't have the alarm. Still I used the interior mirror with the alarm LED, since it was somehow much cheaper than the one without.
Reactions: CmdrBond
Thanks again to all for this info and the parallel thread re foldable chromatic mirrors. I've been able to install and activate both.
Now, my interior mirror automatically dims and causes the driver's exterior mirror to dim. But the passenger mirror does not, and appears to not be a dimmable type. I happen to have a spare passenger mirror glass that does dim, so will try to find out how to get that working. I'll likely disassemble the pass mirror over the weekend. Does anyone have experience with getting a non-dimming passenger mirror to dim with a capable glass? Is it wholy dependent on having the dimming circuit in the controller block mounted on the back of the mirror? I'm a little reluctant to open up that block to add wires for dimming unless it can be done.
TIA
TIA
Yes, read this thread in its entirety, but especially this post.
Mini F56 Auto Dimming Interior Mirror Retrofit
This was carried out on a 2014 F56 Cooper S.
The main aim is to populate pins 3, 6 and 10 in the plug that goes to the mirror.
If your car has an alarm, pin 10 will already be populated with the ground wire.
If you don’t have an alarm, you may not have a plug at all. You will require part number 61 13 6 909 008 to be able to carry this out.
I couldn’t see any additional wiring required for universal remote control or the compass version. I didn’t want them so can’t guarantee that they will work.
Tools Required:
Plastic trim removal tools
Torx screwdrivers
Small flat blade screwdriver
Soldering iron and solder
Insulating tape
Parts required:
The correct mirror for your spec of car. (mine was part No: 51 16 9 285 374, I have an alarm, but didn’t want universal remote control)
2 or 3 x BMW part no: 61 13 0 006 663
15ft of 22 gauge wire
1x Power distribution box contact TE-1241388-1
Running the power cable to the fuse box was a bit easier for me as I was hard wiring a dash cam at the same time. This allowed me to incorporate the power wire into this loom. In theory you could link this in to any 12v feed, but I chose to run it to the correct location at the rear of the fuse box.
If this option is not for you, scroll to the bottom for an easier option!!
Firstly, remove the glove box, front passenger side kick panel and sill trim, passenger side dash side trim, passenger internal A-Pillar trim, the front roof console and rear view mirror trims.
Instructions for this are available from ISTA.
Remove and unplug the original interior mirror. Do this by gently pulling it, parallel to the windscreen, down towards the dashboard. Have one hand underneath the mirror as it may come loose all of a sudden. A bit of wiggling does help. Do not pull back on it as you risk damaging the windscreen.
Coming from the headlining you should have a 10 pin black plug, A60*1B, for the mirror, and a small 2 pin plug if you have a rain/light sensor. We only need the 10 pin plug. If you have an alarm, pins 9 and 10 should already be populated
Solder a length of the 22 gauge wire to one of the 61130006663 wires so that it can be routed along the roof line and down the A-pillar to the fuse box.
Gently, and I mean gently, pry up the retaining tab on the top of the plug with a small screwdriver. Insert this terminal into location 3 on the 10 pin plug behind the mirror. This is the power wire for the mirror.
The other 61130006663 should be inserted into location 6 on the 10 pin black plug. This wire is the LIN (local interconnect network) signal wire. It is long enough to be connected without needing to add any wire.
In the long thin black plug, E131*2B, that was removed from the left side of the roof console, you should find the correct violet/yellow wire in position 2
Solder the wire from pin 6 into this wire and insulate properly.
Neatly run the power wire along the front of the roof, down the A pillar and towards the fuse box. Try to wrap it into available looms as you go making sure there is no chaffing and plenty of slack at corners.
Run it behind the fuse box and cut to length and crimp the TE 1241388-1 on to it.
You will need to find terminal 15 in connector Z7*3B. Remove the blue locking bar, using a small screwdriver, from the fuse box. Insert the connector you just fitted and replace the blue bar. Insert a 5 amp micro fuse into the front of the fuse box in position 52.
You can now replace all of the parts that were removed to start with. Make sure the wires for the rain/light sensor and mirror are inside the plastic trim. Leave the sill trim till last and make sure the rear of it is properly seated into the ¼ panel trim.
You will need to code the rear view mirror in using ESYS.
You can change the FA (Vehicle Order) by adding option 431, this is the easiest option.
Or to code it in manually:
3120>ISP_EC set to: aktiv
3120>ISP_KOMPASS set to: nicht aktiv (default) (Aktiv if you have the compass)
3120>LIN_ISP_VERBAUT set to: aktiv
3120>PF_INMI_LIN_VAR set to: ISP_k_MINI_EC_DWA
(ISP_k_MINI_EC if you don’t have an alarm, option 302)
Now, having looked over this again, there is an easier way if you don’t want to go to the trouble of routing a wire to the correct location in the fuse box.
Remove the trims for the mirror and the complete front roof console.
If you have an alarm, insert a 61 13 0 006 663 into positions 3 and 6 on the 10 pin plug, A60*1B, for the mirror. If you don’t have an alarm, put an additional pin into position 10. The wire on these pins are the same colours so mark them with a piece of masking tape, with the pin number on it, so you can identify them later
Insulate the wires together and route them into the headlining and out of the opening for the roof console. Locate plug E131*2B in the roof console loom. Solder pin 3 to pin 3, pin 6 to pin 2 and pin 10 to pin 1 if you need to.
Carry out the coding required and that should be it.
Refit the trims you removed.
For those of you that want to go with the fuse box option, I have 4 of the fuse box terminals left as I purchased 5. I was not able to find this terminal on BMW ETK, so had to buy them online after I identified what they were.
The first 4 people to let me know can have one each, and if required, I will crimp them onto a length of red 22 gauge wire.
If you have any questions, I will do my best to answer them.
Thank you for this. I had to replace my mirror and ended up getting an auto dimming from a wrecker. Looking forward to getting it working.
I could use some help though. It looks like I don’t have the 10 pin connector. I’d like to go the long route of hooking it into the fuse box. Should I still just connect pin 10 to the relevant roof panel pin or should it be routed elsewhere?
21 - 32 of 32 Posts
