My mistake. I just took a ride and it works unless you only push the clutch about half way in. If its about half way in then it doesn't engage.
Jeremybingham, you are correct as well. Once the clutch is in, you then select the gear and the rev-match engages. Key here is that you have to push the clutch in first, (at least half way in).
