1 - 9 of 9 Posts
I've just noticed that the black roofline (gutter) on my 2014 F56 is starting to show corrosion under the black trim where it meets the A pillar.
I'm thinking it might be possible to cut the black trim on the underside, peel it back, clean out the corrosion and stick the trim back down. Or make a clean cut in the black and use some black belt line tape to make as good a repair as possible?
Has anyone tackled this or does anyone know of an alternate way to fix this?
That's really really unusual, have you had a new screen and the paint has been damaged?
Not to my knowledge.
The car is relatively new to me but there is nothing in its history to indicate a replacement screen.
My description was a bit vague so here is a photo.
You can see the corrosion starting under the black coating.
Hood Automotive lighting Automotive tire Automotive design Motor vehicle
Hi @Everywhen
Never had to deal with this myself but I have seen this part removed in order to have PPF applied on the roof
IMO I would remove that roof molding/rain gutter trim and discard it, resolve the issue with corrosion and install a new one :)
- The MINI is a '14, maybe the trim is cracked/worn and its allowing more water underneath it causing the issue
MINI OEM part number: 51337300002
ECS Tuning site with pictures of the underside of the component
: https://www.ecstuning.com/b-genuine-mini-parts/roof-molding-rain-gutter-right/51337300002/
I hope the issue gets resolved and keep us posted,
Rich
As long as its the moulding and not the roof it's pretty common on many cars I've seen around but not Mini. As above,replace it asap?
1 - 9 of 9 Posts
