I am getting blinded so tried to adjust mine - I have one with a clear plastic 'dome' below the mirror as per second pic. I can't move the knob at all!!!
Any ideas?
Cheers
Any ideas?
Cheers
Yep, my smooth useless knob is the same, very, very tight and I had to get a damp rag for grip to initially move it several times before it can be moved by hand and still it is extremely stiff to turn.I am getting blinded so tried to adjust mine - I have one with a clear plastic 'dome' below the mirror as per second pic. I can't move the knob at all!!!
Any ideas?
Cheers![]()
No, the mirror in question is the manual adjustment spec with the clear smooth knob that will with a lot of effort turn through 45 degrees and dim the mirror.Maybe I'm not understanding the problem here, but it looks like you are attempting to adjust the automatic mirror by wrenching on the photocell?
Not seeing why the automatic dimmer would have a manual adjustment.
I would go to the dealer and have them explain it to you. You probably don't want to apply so much force that you break the photocell off and have to buy an expen$ive replacement...
This for the help folks... Just double checked - the white dome seems to be for the 'alarm armed' light ( does it double up as a manual mirror adjuster as per my original pictures? ) but never mind - I DO have the photocells for auto dimming - But hey - I DO MIND - its just they don't seem to dim a lot, especially with an idiot behind me with extra strong headlights driving in my boot!No, the mirror in question is the manual adjustment spec with the clear smooth knob that will with a lot of effort turn through 45 degrees and dim the mirror.
It is the fact that the clear knob is smooth and tapered that prevents a grip being applied to turn it, so in my opinion it's a useless design feature that's gone one step beyond sensible.![]()
Okay, I see what you mean. Looked at the manual; I agree, what a dorky design.No, the mirror in question is the manual adjustment spec with the clear smooth knob that will with a lot of effort turn through 45 degrees and dim the mirror.
