1 - 9 of 9 Posts
The stock brakes on the Clubman are different than the F56/F55 and are not interchangeable. Wheel size is an issue as well.
The jcw discs are the same as the f56, I assume servo etc is required because it's a heavy car
The jcw also uses different servo to the std f56 but offered for std car retrofit kit
Same as the F56, yes, but not the F54 which has bigger discs in front and rear.
I also totally missed there is already a part number for the F54 JCW brake kit, which is indeed different than the F55/F56 brake kit.
So can rear f56 be upgraded to f54
I feel a plan forming .....
1 - 9 of 9 Posts
