1 - 6 of 6 Posts
In my never ending quest to get Android Auto, I struggle to even take out the headunit from the dash. I can easily unscrew, prod and pry everything except for the top portion of the headunit. No matter what I do (insert screwdriver into tiny hole while pulling, push unit from behind via top stereo/vent), I just can't seem to pull the unit out. Granted, I'm not using all my force because I'm afraid to break it but still, I can't even feel a tiny bit of give. Is there a trick to pulling it out? Attaching pictures to make sense of things. Oh I also pushed in one of the rivets push pin a bit too hard and the inner lock fell (somewhere behind the headunit area). Luckily I had a spare but it's not OEM. Any places I can get it for relatively cheap? Would the dealer have them?
Automotive lighting White Motor vehicle Hood Automotive tire Water Automotive tire Rim Bicycle part Automotive exterior
The trick to get the top off is press down using a flat head screwdriver in that centre hole, while pulling evenly with your other two hands. ;)
The pin part number is 65509347047
Oh good. My third hand finally gets to do something useful. Thanks for the part number!
I actually did this myself yesterday and can only agree with what navwizard said and mention it does need a decent tug based on my experience
While it's still fresh in your memory, did you push down with a screwdriver while pulling simultaneously or did you just push down a little bit and then pull with both hands? Which direction were you pulling? Upwards, straight or downwards? Also, as you push down, do you feel the tab move at all? I tried doing it but didn't really feel anything give.
All good questions.
I had removed side screws and validated that there was some sideways movement when I wiggled it with 2 hands. I then felt inside to locate the catch. At first it was clearly protruding, I then pushed down with the screwdriver and wiggled one handed from the front sideways back and forth. I then stopped pushing down from top and could feel that the catch was now completely gone i.e inside of casing so continued with 2 hands from front. I would say at this point it was a little wiggling and downwards in motion with a bit more force.
hope that hepls and good luck
1 - 6 of 6 Posts
