Yesterday the Service Department installed a new Air Bag and had to disconnect the Battery Drove the Car home all was fine I also installed some new factory Valve Steam Caps that I picked up at the Parts Counter and put them on. I made sure they are not put on to tight so it would not touch the tap. Drove to work Display was fine the car was sitting for 11 Hours. On the Way home the Display showed that all my Tires are low on air.
So I checked the tire pressure today and here are the numbers
LF 28.5 PSI
RF 28.3 PSI
LR 30.0 PSI
RR 29.3 PSI
all 4 tires are low at the same time sure is weird imho.:|
Had the tires filled with 35.0 PSI at Discount Tire and did a reset. I will keep an eye on the tires but I wonder if my Sensors are ready to strike because of the AZ Heat or if it had something to do with the disconnect of the Battery? Anybody else had a similar problem?
LF 28.5 PSI
RF 28.3 PSI
LR 30.0 PSI
RR 29.3 PSI
