1 - 10 of 10 Posts
Hi all,
I am not if you remember, I got a TPMS failure message the moment I had left for France last month and the sensors couldnt fetch the preassure reading and it kept on going in circles. After a few hours if just worked.
For the last couple of weeks it has started to happen again. I keep on getting a yellow flashing light saying that the TPMS has failed.
After searching about it online, I found that it has something to do with the dashcam interference. It sounds a little strange however I am going to give it a go without the dashcam and see how it goes.
Has this happened with any one over here?
Saurabh
Yes ; is it one or can't you tell; if one tpms has failed it's just the unit in the tyre; simple fix; BUT of course it could be the central processor itself; mmmm! Let's hope it's just one dodgy battery!
I've seen the TPMS fail on a few f56s - ends up being either a faulty sensor or bad programming, in which case, a reprogram fixes the issue.
3rd party TPMS sensors can also cause all kinds of issues, but that doesn't sound like the case here.
After 50k miles it could be the sensor batteries have gone-how old-they have a 5 year life but depends how much you use the car too!
So a random thought here
as a last ditch attempt to try and avoid changing these, try a toothbrush charger over/behind the tyre valve for a couple of hours
just had it flash up briefly on the motoway for about 5 miles then back to normal
I will give it ago this coming bank holiday weekend myself
1 - 10 of 10 Posts
