Hi all. Running a 2015 JCW for the last 2 weeks and have noticed a distinct rattle from the back of the engine when light throttle.
You can see/hear what I mean if you search 'AX65KXE rattle 2' on YouTube (can't post links yet but when I can will update with direct link.
Wondering if anyone has had this issue and know of the solution? I sent the above clip to my Mini dealer and they advised to get it in for a check under warranty. Having had the car in, and tested against another customer car, apparently they've said this as normal.
My own research has lead me down the classic BMW N54 335i turbo rattle, where the actuator arm is loose and is rattling (especially when on low boost option like Green mode). Often, these turbos were replaced under warranty. I can't find much else on this online and the lead tech at the Mini garage wasn't aware of this noise and is actively enquiring internally.
I've written back to the dealer following the N54 comparison and waiting to hear back.
Anyone on here have the issue? Keen to hear thoughts on any research or tech views.
Thanks!
FZB
Thanks!
FZB
