Really don't like the brakes on my MCS. Lack of feel and not enough stopping power when pushing hard. Would love the JCW upgrade but not when the cost factors in new wheels. Does anyone know of any third party solutions?
Testing new cars back to back won't give you a very good idea. Neither is impressive until they're broken/bedded in properly. Whatever you go with I definitely recommend stainless braided lines on all four corners. They will help reduce any soft spongy feel.Maybe JCW brakes on a standard car feels different from how they feel on JCW ...
When I tested MCS and JCW back to back brakes was not thing of note
My day understanding with brakes is that the higherend brakes is that that can take the abuse without fade for example when u trashing it at the track ...
Demo cars are not new they have lot of mileage
This whole brake upgrade for none racing drivers is really just something you do to make yourself feel better...its not a functional upgrade ...
"Originally Posted by vetsvette View Post
Testing new cars back to back won't give you a very good idea. Neither is impressive until they're broken/bedded in properly. "
Emphasis on the work properly.
Also after reading your last sentence, it's obvious you've never been on the Dragon, or the roads in that area.
This is a difficult question to answer. A great deal of it would be your dealer, some will try to minimize their costs and not honor any modifications that might impact the warranty and others would be fine with modifications. Are you going to do the modifications yourself or have the dealer perform the work? If you upgrade your existing brakes with either the JCW 4 piston bembro brakes or the GP 6 piston bembro brakes and have the dealer perform the work or an authorized BMW service center it should not affect your warranty, but check with your dealer to be absolutely sure.Definitely following this thread. The brakes are hopeless. I mean, they do eventually stop the car, but they lack any feel, don't inspire confidence, and IMO high speed stability is a serious issue.
I'm really new to this, so I don't know what pads/fluid would you recommend? Does replacing this stuff have any bearing on warranty?
Mmmm not 100% convinced; like many on here i find i can quite easily lock my brakes if i brake hard-for me since i am not on a race track, that is enough-and feel for me is as good as any car i have had-yes different cars have different sensitivities but if you can trigger the abs ie lock the brakes then there's enough stopping power per se. HOWEVER if you then increase the grip eg sticky race tyres, and add more power then of course it's worth an upgrade as you might get to the point when grip exceeds braking capacity.
HOWEVER if we are talking brake fade after repeated application of hard braking eg on a track or unusually VERY hard road driving , then fair does-i agree the brakes may need an upgrade-hence my question. i've not yet achieved fade in my mini BUT you might on a long down hill run with numerous bends etc. I fully accept that doing this hard fast road driving regularly might need a brake upgrade.
If the first case arrives then there isnt a need for more braking power-BUT some eg the op may not like the feel ie the brakes dont feel sensitive enough eg after driving other cars-Citroen in the past were notoriously over assisted for eg. then it's a case of spend lots or get used to it! Just for feel-i find i get used to it (our f series brakes are much sharper than our r series roadster s!).
