I just looked under the rear cargo flap for my 2015 MCS and noticed the water had gathered around the toolkit, has anyone else had this problem?
I just looked under the rear cargo flap for my 2015 MCS and noticed water had gathered around the toolkit, has anyone else had this problem?
Yes, I just found that I had 3 inches of water in the toolkit well after heavy rains, and mold growing underneath both cover panels!!I just looked under the rear cargo flap for my 2015 MCS and noticed water had gathered around the toolkit, has anyone else had this problem?
I have the same problem! So seems like it's a common problem with this generation of mini? I'll contact the dealership asap to have it fix, should be under factory warranty right? How long does it take for them to fix it and what's the outcome? Thanks.I just looked under the rear cargo flap for my 2015 MCS and noticed water had gathered around the toolkit, has anyone else had this problem?
Pulled the rubber plug and drained it, mopped up everything and used a shop vac to get as much water and mold out.
I thought that maybe it was my fault by leaving the hatch open at some point, but unlikely. Next rain, sure enough - small amount of water in the tool well, and again the panel above it was wet.
I will be taking a hose to it tomorrow to see if I can reproduce the problem, and maybe see where it's leaking. Also best to be able to reproduce it so the dealer can see the issue first hand...
Best check mine again tomorrow!Hi there I'm new to the forum and looking for some help/info/ friendly advice ?i bought my first mini on Friday and noticed today, after alot of rain, that there is water in boot. It's sitting in the well where the puncture repair kit sits. I just wondered if anyone else has had this? What was the problem? I phoned the dealer to query and parts dept will call me tomorrow bit I was basically told that they've never heard of this in a mini before!! Any advice would be great. It's a 2015 mini one D.
