Ok,
@DarthDude — just so you can relax, here is today’s trip. Setup: started with a full charge; overcast skies but dry roads; temperature at departure was
3°C (pretty sure that’s never going to be an issue in Malaysia!), rising to 5°C by the end of the trip; Mode set to Green for the whole drive, while climate control set to Auto at 20°C; the MINI is wearing beefy Nokian Hakkapeliitta R5 winter tires (195/55R16) at the recommended 38/35 psi; and the drive was a roughly 1:1:1 mix of motorway (120+ km/h), two-lane country roads (50-80 km/h), and suburban streets with stop-and-go traffic (at up to 60 km/h).
Here is the output from
GvilleGuy’s efficiency calculator:
Mar 21, 2023 at 14:59
5 °C
Wind: 15.83 km/h from W
Humidity: 61%
Driven: 171 Km
Start-Batt: 100%
End-Batt: 10%
Km / kWh: 6.57
GOM Reading: 14 KM
Calculated Range Left: 18.99 Km
Total Range (From 100% charge): 189.99 Km
Note the the EPA/NRCan estimated range for the 2023 SE in North America is 183 km under ideal normal conditions, in mild weather on efficient summer tires. I suspect with your comparatively smooth roads and balmy weather (I was last in KL perhaps five years ago), that you should
easily match (and surpass) my winter numbers. 👍🏼🙂
