I have a funny issue with my satnav on my 2016 JCW (with the big screen)
About a week ago I was messing about with the Settings and set the default map display to 'night mode'. This worked as expected and the car would start with the map in night mode.
Decided I didn't like it though so changed it back. The problem is that this second change won't stick. Essentially no matter what I try the Sat nav is stuck in night mode. I have tried changing it back to 'auto's and 'daytime' and turning the car off (which should save the current settings) but it never does anymore!
The same has happened with muted voice directions. I turned them off once and now they default to off even if I change them back on and then turn the car off overnight.
Same with map view. This is stuck in the perspective view.
Always use the same key....... any ideas? Is there a way to 'reset the settings to default some how?
Any thoughts?
Any thoughts?
